EMUSA wastegate spring Q
Old Oct 25, 2017 | 06:19 AM
epfatboy's Avatar
Default EMUSA wastegate spring Q
Quick Q folks, been looking at the EMUSA 50mm VFlange waste gate with a 14psi spring for my JY build.
Is there 2 springs in there? I'm pretty sure I read there was a small spring at 5psi and a larger one which was ??.
I'm looking to run like 8-10 psi with a MBC and I was thinking the small (5) spring would do the trick.
Old Oct 25, 2017 | 08:18 AM
squarles67's Avatar
I have 2 EMUSA 38mm gates and the light springs are indeed 5 lbs. if I let it revert to spring pressure.
I'm running 15 lbs. using Holley boost control through my Dominator setup.
Old Oct 25, 2017 | 10:13 AM
epfatboy's Avatar
Thanks, guessing they use the same springs between the 38 and 50. I do have a note into the supplier (speedyracer) to verify.
I'm going manual for now as this is a cheapo build, to date I have not come across anyone with a DIY boost controller using a stock pcm, seen them using the mega squirt on sloppy's wiki... that looked in budget for sure if I knew it would wire to the stock pcm.
Old Oct 27, 2017 | 01:55 PM
epfatboy's Avatar
Crap, single spring....
