best boost piston
Old Nov 1, 2017 | 02:32 AM
Detoxx03's Avatar
Originally Posted by Rudy72
something like this with Callies Ultra H-Beam Rod!
custom Diamond, coated top and sides are hard anodized, 4.125 bore
Hell yeah
Old Nov 1, 2017 | 07:26 AM
Rudy72's Avatar
Default Awesome HP
Originally Posted by Detoxx03
Hell yeah
Horsepower designed by a Master HP maker!! Diamond provides exactly what we need!!
Old Nov 1, 2017 | 07:49 AM
Forcefed86's Avatar
If you are planning on a stock block build go with factory stock bore piston. With the OP's weight and desired power level, the last thing you want to do is run a 4.125 bore piston and stroke it. 6 liters is plenty to make 1200whp... Factory stroke, factory length rods, and factory bore will result in the strongest most reliable rotating assy in a stock block. Even then you aren't going to be what I'd consider reliable.
This is a 370 that was split around the op's desired HP levels and only 3300ish lbs. Add a ton more overbore and additional side loading from more stroke and you just weaken it even more. Don't buy into vendor BS trying to upsell you a large cube engine if you run a stock block.
Old Nov 1, 2017 | 02:08 PM
tblentrprz's Avatar
Reliable combo, 5.3 (lots of bore material, more stable), 3/4" deck heads (more flow/more stable, less boost required), 1/2 studs (more consistent/stable clamping force) Spec rotating and valve train assembly to spin 8K which gets you the air flow of a 6.0 at 7K. Tune to keep it alive for many runs.
Capizzi is setting the mark with SBE 5.3. With better rotating assembly, you should be good for a few seasons before tear down and inspection.
Old Nov 1, 2017 | 03:19 PM
transam69230's Avatar
Less boost ? LOL, you know Capizzi is like 35lbs plus right ?
Old Nov 1, 2017 | 04:48 PM
tblentrprz's Avatar
Yep, 35+ on thin stock deck 799 heads. Amazing they hold. The magic is in the tune and rpm. I'd estimate 1200whp at 28 - 30ish with aftermarket heads.
Old Nov 1, 2017 | 05:43 PM
Game ova's Avatar
Old Nov 1, 2017 | 07:56 PM
3 window's Avatar
Originally Posted by Game ova
If that goes wrong, they’ll never find that kid.
Old Nov 2, 2017 | 11:42 PM
transam001's Avatar
thanks for all the imput guys. i know everyone will have a different opion but you guys had some good points for me to look at. like running a 370 like i am now instead of a 408
