Application
Old Nov 6, 2017 | 10:27 PM
mrneil65's Avatar
Default Application
I have an 85 monta carlo which i purchase less engine and trans. wanted to run LS1/LS2 for bracket racing. has 4.56 gears. weights about 2400lbs. would like to have about 525 hp at the motor. no power adders. just started racing. Is this a good idea?
Old Nov 7, 2017 | 12:02 AM
GIZZ's Avatar
Yes.
But 2400lbs? You’re talking about the Monte as a roller?
Old Nov 7, 2017 | 12:24 AM
silvea's Avatar
You will get better info posting in the gen 3/4 external section
Old Nov 8, 2017 | 12:30 AM
mrneil65's Avatar
Default Application
rolling chasis weight is about 2400/2500 lbs, What type auto trans should I install? trying to run low 10s in the 1/4 mile.
Old Nov 8, 2017 | 11:51 AM
Forcefed86's Avatar
You’re in a power adder section asking about a no power adder setup.
Most G-bodies are heavy. I’d guess you’ll be 3600-3800+ race weight. So 525 HP probably won’t net you 10’ unless it's been lightened up a ton.
Honestly no power adder or “NA” is the expensive route to a 10 second slip. Add a $640 S475 turbo to a bone stock 4.8/5.3/6.0 (even without a cam) and you can have a 10 second slip pretty easy. TH400 or built glide for the trans on a drag car. Lighter and easier to work on/control than the 4l80e. I’d sugest ditching the 6.0 idea and going with a 5.3/4.8. They are much cheaper and will do the job.
