which head casting for destroked 6.0?
Old Nov 22, 2017 | 09:46 AM
Rebelfromva's Avatar
Default which head casting for destroked 6.0?
Starting a new 6.0 build using the 4.8 crank. 6.300 rods. Will be a turbo build in a chassis at or below 3k lbs. auto th400. With this build I would like to use a cam motion cam with the appropriate valve train to turn 8k. Track car mainly with ability to drive to the track.
Main goals of the build are
turn 8k
1000+ hp.
e85
With a setup of this nature which head casting has proven itself? I'm a fan of the ls3 heads, while many are not. With the 4.0+ bore I am leaning towards these but being destroked would any other casting fit the bill better 082 317 799s? The valve train is going to be upgraded springs rollers possibly valve sz/type if needed.
Old Nov 22, 2017 | 09:57 AM
Tuskyz28's Avatar
Trickflow
Old Nov 22, 2017 | 10:00 AM
Originally Posted by Tuskyz28
Trickflow
ls3 799 082?
Old Nov 22, 2017 | 12:26 PM
TrickFlowTech's Avatar
LS1Tech Sponsor
If you are at a 4.030+ bore, the TFS-255's begin to make sense if that's the way you're leaning anyway. There are more LS3 intakes coming out to suit your rpm range. As you stated, a heavy duty intake valve would be a good idea with appropriate springs. 6-bolt casting could be used if you ever decided to go with an LSX block etc. at some point.
__________________
Old Nov 22, 2017 | 03:09 PM
Cwarta's Avatar
turn 8k
1000+ hp.
e85
have you seen the head comparison test that cane out? The texted various heads on a 5.3, both n/a and forced induction, and as hard as it is to believe, the 706/862 head made more power, by a good margin, than 317,799,241 etc.
Old Nov 22, 2017 | 04:07 PM
yes and I seen a 317 vs ls3 on a 6.0 na and fi test he did too.
Old Nov 22, 2017 | 07:22 PM
Taubr Unit's Avatar
Trick Flow Tech, you guys running any Black Friday sales? I'm also looking for a set of heads for my build also! Lol.
*sorry to hijack thread*
Old Nov 25, 2017 | 09:43 AM
89BANDIT's Avatar
Also going with the TEA TFS 235's. Im also hoping to spin it north of 7200. But not destroking it.
OP, What intake are you going with?
 Michael S. Palmer
Old Nov 25, 2017 | 01:32 PM
gnx7's Avatar
These new LS9 heads are also good bang for the buck:
Titanium intake valves....
https://www.summitracing.com/parts/nal-19328743
Old Nov 26, 2017 | 11:43 AM
helicoil's Avatar
Nice deal right there for 4bolt heads.
What intake choices are there for those?
