Spark plugs ?
Old Nov 23, 2017 | 10:42 AM
1993lt1's Avatar
Default Spark plugs ?
Whats the best plugs and gap for boost.
Old Nov 23, 2017 | 01:40 PM
Lsxford's Avatar
Well, it depends.
im sure this has been covered before, theres also recommendations on the sloppy mechanics wiki<---- it.
But i use NGK BR7s with out of the box gap (.028?) for lowish boost, like less than 15-16 on my setup. But theres other factors besides boost pressure that should factor in. For a mostly stock engine they will work good less than 18 psi IMO.
Old Nov 23, 2017 | 02:54 PM
truckdoug's Avatar
i use tr6's for low boost (~12psi) on pump **** 91 and 70/30 water-meth. never had a problem .028 gap.
switched to br7ef right at the end of the season when I upped the boost to 14psi, never got traction for a full pass tho.
Old Nov 23, 2017 | 04:13 PM
Game ova's Avatar
I will probably get told I'm crazy for this, but I use TR6 with a .28 gap. I've had it as high as 22psi.
Old Nov 23, 2017 | 04:23 PM
handyandy496's Avatar
All depends on the fuel.
Old Nov 24, 2017 | 03:02 PM
squarles67's Avatar
Above is from Sloppy Mechanics
Old Nov 24, 2017 | 05:26 PM
1993lt1's Avatar
Thanks that helps
Old Nov 24, 2017 | 11:21 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Chalk it up to the current craze of boosting high CR motors. I have to admit, though, I finally got peer pressured into using br7's.
Old Nov 26, 2017 | 06:10 AM
forcd ind's Avatar
I use 7's, ads some insurance, and with a good tune they burn fine, never fouled one, always look good-I gap them 28, but mostly street car, so I prefer a little wider gap.
Old Nov 26, 2017 | 06:49 AM
ddnspider's Avatar
I run nonprojected 7s. There is no downside only benefit to a slightly colder plug and as long as the tune is good you shouldn't foul them.
Old Nov 26, 2017 | 07:45 PM
gametech's Avatar
It would be nice to know the "real deal" with sparkplugs now. Since the advent of FI, there are no more worries about fouling a cold plug, so how do you determine if a plug is too cold? Too hot is simple, but where do you draw the line?
Old Nov 26, 2017 | 07:51 PM
truckdoug's Avatar
when it doesnt hold enough heat in it to self-clean
