Wastegate plumbing
Old Dec 10, 2017 | 09:32 PM
Bbcpoweredz28's Avatar
Default Wastegate plumbing
Ive been looking everywhere on how to plumb my vacuum lines for the wastegates. I got a great deal on somePrecision units so I dont have any paperwork. Im running twin S366s with twin gates. Need a basic plumbing diagram or walk through to just run gate pressure for now. Its a brand new build from the tires up so I dont want to lean on anything to hard yet. Yes I looked at the sticky but all the pics are gone and didnt really see any descriptive posts the didnt need the pics to be deciphered.
Thanks in advance.
Old Dec 10, 2017 | 11:10 PM
3 window's Avatar
Go from your pressure source (compressor) and tee off to the bottom port of both gates. Thatll get you spring pressure and the lowest boost level you could achieve with whatever sprIngs you have.
Old Dec 11, 2017 | 09:51 AM
Ok so anywhere pre throttle blade to avoid the gates seeing vaccuum. Leave the top port to atmosphere of cap it off?
Old Dec 11, 2017 | 10:10 AM
3 window's Avatar
Yes. Some go pre intercooler, some post. Im right off my compressor housing and it works well. If no line is connected to the top, leave it open. If you cap it youll create a closed space in the dome and the air trapped in the dome wont be able to escape when the gate needs to open and youll drive the boost higher than intended.
Old Dec 11, 2017 | 10:13 AM
Ok thanks man. I appreciate it.
Old Dec 11, 2017 | 10:15 AM
Fuhnortoner's Avatar
If you have a nipple on your turbo outlet you can use that
Old Dec 11, 2017 | 10:17 AM
01ssreda4's Avatar
http://www.turbosmart.com.au/wp-cont...Y_12_rev-2.pdf
Old Dec 11, 2017 | 06:57 PM
Right click, Save As
Thanks
