Here we go....slow
Old Jan 5, 2019 | 11:51 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
tuning my own stuff is pretty much the best part. instant gratification.
You and I must be tuning differently, because "instant gratification" would be the last idea on my mind when it comes to dialing in a combo.
Old Mar 1, 2019 | 06:44 PM
thedetroitkid's Avatar
Some progress!
Getting ready to mock up my radiator before I get my bov set in stone
Old Mar 2, 2019 | 09:52 AM
mightyquickz28's Avatar
Glad to see I'm not the only one taking the "Slow but steady progress" path. We're getting there, inch by inch. I only get to work on mine anywhere from 15 minutes to (rare) 2 hours a day. That includes driving to/from the shop (about 200 yds away). By the time I get the lights on , the propane heater fired up (it's 28 degrees here today) and remember where I left off, it's almost time to go back home. But, like you, it's creeping towards completion.
Old Mar 2, 2019 | 06:51 PM
Some more of my handy work
ok so got my radiator ordered, gonna try to trim and run the stock fans , so we'll see how that goes.
Old Mar 4, 2019 | 02:02 AM
freeky's Avatar
im doing the slow but steady build to . mines because of money lol keep it up . dont lose your motivation . good luck
Old Mar 5, 2019 | 06:28 PM
Ok more handy work underway, got my tranny cooler mounted and some radiator brackets mocked up.
Old Mar 7, 2019 | 05:03 AM
boosted-delslow's Avatar
Looks good. I am doing a similar project. I also took the slow and steady route. Between kids and work it took me almost a year to complete. You cant get a whole lot done when you work on it 30 mins at a time. LOL
Old Mar 8, 2019 | 01:49 PM
Same here. I'm doing good to complete a single 360 degree TIG weld before I get the call to come back home. Still have to complete the drivers side turbo's downpipe past the K-Member, then drivers coils/plugs/wires. One more Wastegate to plumb in. Gotta pull off the front Fascia to get to the intercooler to convert it from 3" in/Out to 3.0" in *and* 2.5" in retaining the single 3.0" out. That's all the big stuff. Afterwards, details like where to place the overflow bottle, routing the intercooler outlet to the TB.
Old Mar 8, 2019 | 03:31 PM
freeky's Avatar
i camt wait to start putting the work in . im still buying parts for mine
Old Mar 8, 2019 | 06:15 PM
Wow , I'm literally doing everything backwards compared to that picture, but my radiator showed up and I'm getting excited!!
Old Mar 12, 2019 | 07:15 PM
Got my exhaust mostly fabbed up!
Old Mar 12, 2019 | 08:19 PM
  #32
Woo Hoo! Hope she'll be ready to drive soon.
Old Apr 21, 2019 | 09:05 AM
  #33
More handy-work! Got the 80e installed along with converter, these twin walbros sound nasty kicking on! Gives me a lil chubby. The todo list is getting a lot shorter now
Old May 17, 2019 | 05:04 PM
  #34
Checked my oil and found coolant in my oil. Coolant blowing out the exhaust also at idle. Now after doing cam, springs, oil pump and timing chain to a motor with a cracked block or head , I can’t tell where the leak is at so far trying to pressurize the radiator. I’ll be in the market for a replacement long block assembly, Really bummed out , wanted my car to be driving this year by now.
Old May 19, 2019 | 08:32 PM
  #35
f8lvenom's Avatar
That sucks...sorry to hear man. Good luck getting her together.
Old May 21, 2019 | 07:50 AM
  #36
freeky's Avatar
it might jus be a head gasket
Old Feb 21, 2021 | 04:09 PM
  #37
Back from the dead..the 4.8 had the wrong head gaskets. The notched 862’s didn’t seal the mls gasket I previously installed. Myself broken and battered from my wife complaining about my project car that doesn’t run. I continue my quest for melted highway rubber in optimistic stride.
Now the here and now :
- Id base metal of cylinder head at work
- weld notch hot and fast with my tig pedal
- waiting to order forged boost-lines and btr rods
- have the lower rotating assembly balanced & block hot tanked and punched ( by my engine guy) and reassembly after gapping the rings.
- ls9 gaskets
- any thoughts or criticisms?
- on the second hand I’m contemplating throwing it back together as budget as possible and upgrading the rear end instead of the rotating assembly. I’ll have maybe 300$ having my heads tanked and milled.
