Gear Driven Procharger help
Old Dec 24, 2017 | 03:18 PM
KevinsHVAC's Avatar
Default Gear Driven Procharger help
I am currently gather parts for my build. I had a few questions regarding belt driven components and how and if they can all work together. Motor will be RHS 460. I am going to be running the F-1X-12 gear driven blower, jesel belt drive, external wet sump, and belt driven fuel pump. Can all of these be ran using the jesel belt drive AND procharger gear drive?
Old Dec 24, 2017 | 03:24 PM
KevinsHVAC's Avatar
Or just get two Aeromotive A1000, and do away with the belt driven fuel pump?
Old Dec 25, 2017 | 10:45 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I have no idea what your drive options are with that setup, but I would strongly recommend sticking with the belt driven fuel pump. An A1000 might be a good primer pump, though. On the other hand, your goals might not be quite as lofty as what I am picturing from an RHS 460.
Old Dec 26, 2017 | 11:24 AM
vinceI's Avatar
You can run both of your pumps off the drive unit. You have 3 drive options off of the drive unit. 2 spin engine rpm the others rpm is dependent on what gear ratio you have in the drive itself.
Old Dec 27, 2017 | 07:25 AM
KevinsHVAC's Avatar
Goals.....registered, tagged, C16 fuel, small tire, as light as humanly possible. Mast or All Pro heads, 1500-2000hp with procharger. Intercooled and radiators. Just trying to see what all I can run with a belt for mechanical.
