Double barb banjo fitting
Old Jan 14, 2018 | 07:32 PM
973800CamaroRS's Avatar
Default Double barb banjo fitting
i found a double barb banjo fitting that changed the way I wanted to route my vacuum hoses. If I run a hose from my intake to my waste gate to one side of the barb then on the other end run a hose to my bov would that be sufficient or should I run two hoses to each ?
Old Jan 14, 2018 | 10:24 PM
Cwarta's Avatar
You shouldn’t have your wastegate hooked to vacuum. Only the BOV
Old Jan 14, 2018 | 10:32 PM
brandon6.0's Avatar
Wastegate can be hooked to turbo or intake manifold My wastegate and bov run off a vaccum block off the intake manifolf brake booster line. Works fine for me. Once u get positive pressure it works the same way. To the OP i dont see no harm in using tht bajo.
Old Jan 15, 2018 | 09:23 AM
laytoncamaroz28's Avatar
I've hooked em up together like that as well. Worked good for me.
Old Jan 15, 2018 | 09:40 AM
Loud Mouse's Avatar
Charge pipe after intercooler b4 throttle blade to wastegate. This will give u the real psi signal to the gate. In the intake manifold after the throttle blade to BOV. This will open the bov when u let off the throttle from vacuum. Mine works excellent this way and very consistent.
