Anyone had luck with 4l60e and 2-step?
Let loose this past fall after I started spinning it to 7000.
It did not like that lol but also was not set up for high rpms. Lasted 2 race seasons and I drive it like a manual lol.
The first thing people do is throw heads and cam on their car that means they need to rev to 6500 or 7000 to run a number....when rpm is the enemy of the 4l60e, and then they wonder why it broke or call it a POS cause it wasn't designed for 7000rpms.
There are three bolt holes left open on the 4l60e tailshaft housing after the brackets are removed that hold the stock transmission mounted torque arm in place. Once the TA and brackets are removed to be replaced with a tunnel mount TA, this leaves the bolt holes open and mty on the tailshaft housing.
I put the bolts back in.
What IMO should be done instead is to make two triangular plates, one for each side (left and right), and then bolt the plates to the tailshaft housing. IMO that would strengthen the rear most end of the longer tailshaft on the 4l60e. It won't add any weight and won't hurt anything. It's on my to-do list.
