Truck manifolds sitting on frame
Old Feb 3, 2018 | 12:29 PM
Airhwhip's Avatar
Default Truck manifolds sitting on frame
I'll get some pictures up as soon as possible.. But I'm in the process of putting my 5.3 swap back under the car and I cannot get my UMI K-member to bolt up because my manifolds are basically pressed against the two sides of the frame. How much clearance should there be? I also recently swapped to poly motor mounts, but I don't think that'd be causing an issue.
At this point I'm thinking I'm going to have to suspend the motor/trans and try to bolt up the k-member without that weight on there.
Any advice/information is appreciated.
