Vortech belt and pulley questions
Old Feb 12, 2018 | 12:06 PM
qwiketz's Avatar
Default Vortech belt and pulley questions
Hi all,
I've been a way for a while (car not running and other projects). What are the best belts for a vortech ysi these days? Is it the gates hd green belts or is there anything else out there that is as good or better? I'm running a standard gates micro v and it's time for replacement.
Also, on the pullies, are there any "magic" pullies out there with more grip than the standard ones? I am running a generic 2.75 right now and have in the past used the "renegade finish" bead blasted vortech one. Every once in a while I see something pop up but it's been a while.
I don't have much of a belt slip problem at my current level but you never know!
thanks!
Old Feb 12, 2018 | 12:53 PM
qwiketz's Avatar
in my search I saw gates rpm but they're only in limited sizes. The closest to mine is a k080600rpm which is a 60". I think I'm running in the high 50's right now (58 or 59"). I'll need to verify but I may have answered part of my question but there may be some work involved with bigger idler pullies.
Old Feb 12, 2018 | 06:02 PM
Realcanuk's Avatar
I run the serated pulleys from A&A which work great. The gates RPM are the new hot belt if they make the size you need. Never really had any problems with the Gates HD green belts..
Old Feb 12, 2018 | 11:48 PM
qwiketz's Avatar
those are the ones with the slots in them right? Did you notice any decrease in belt slip with them?
I did a quick check and they do offer my belt size in a hd but not the rpm so I'll probably give it a go.
Old Feb 13, 2018 | 01:50 AM
TPIZ92's Avatar
In my recent quest for a pulley I came across across the surgrip coating for the pullies, might be worth looking into
Old Feb 13, 2018 | 11:04 AM
Realcanuk's Avatar
Yes.. the ones with the slots.... 00 slip on my setup.
Old Feb 14, 2018 | 06:20 PM
qwiketz's Avatar
i saw that one to. I’m curious how well it works and how long it stays on there.
