fuel system help
Old Feb 21, 2018 | 09:40 PM
m3nd3zls1's Avatar
Default fuel system help
first time ever building a turbo car 99 ls1 Camaro. I need help choosing a fuel pump if I need a single or dual. not sure how a hotwire works. do I need to mess with the fuel rail at all. I know upgrade the injectors but I don't know what size I need. I might need guiding on how to plumb it if I need to. like I said major rookie on building a turbo car
Old Feb 21, 2018 | 10:05 PM
Airhwhip's Avatar
Your power goals determine all of these things you have mentioned. If you start there people can chip in with useful information.
Old Feb 21, 2018 | 10:12 PM
m3nd3zls1's Avatar
i want my power goals to be between 600-650
Old Feb 22, 2018 | 12:38 AM
Airhwhip's Avatar
Gasoline or E85?
Old Feb 22, 2018 | 07:58 AM
m3nd3zls1's Avatar
Gonna keep it gasoline
Old Feb 22, 2018 | 04:35 PM
Airhwhip's Avatar
Alright, for 600HP, a single Walbro 255 with a hotwire and Deka 60 injectors should get you there. A hotwire simply provides a higher voltage to the pump therefore increasing output due to running a power connection directly to the battery (roughly 13.5v) vice 12v supply from the PCM. You can most likely get away with this on the stock system, including stock rails, but a lot of information is available on running new fuel lines (recommend -8AN supply/-6AN return) in which case your fuel system will be built for any future increases in power goals.
Old Feb 23, 2018 | 11:43 PM
m3nd3zls1's Avatar
awesome thanks for the info
