Compression Ratio.....
Old Mar 22, 2018 | 12:57 PM
red fury's Avatar
Default Compression Ratio.....
What compression ratio are the dedicated E85 users running on built motors? Turbo car here....
Thanks!!
Old Mar 22, 2018 | 02:22 PM
necrocannibal's Avatar
My compression is around 10:1 on my 408 turbo car.
Old Mar 22, 2018 | 03:05 PM
bca21's Avatar
Stock motor here, 10.1 800hp my buddy's built dedicated car is 11.1 1200 plus
Old Mar 22, 2018 | 05:13 PM
Detoxx03's Avatar
Still stock bottom end LS3 so 10.7:1 but if/when I build an engine it will be a minimum of 11.1:1 cr. Actually when I bought my rotating assembly last year I had everything setup for just that.
Old Mar 24, 2018 | 03:39 PM
red fury's Avatar
Thank yall!
Detoxx are you going to continue using your stock sleeves or go aftermarket sleeves with your LS3 block? when the time comes...
Old Mar 24, 2018 | 04:00 PM
Detoxx03's Avatar
Stock again
