Pressurized coolant quandary
Old Mar 24, 2018 | 01:00 PM
Game ova's Avatar
Default Pressurized coolant quandary
This is not happening to my motor, but another person I know. It's a studded ls motor with ls9s.... heads torqued to 80ft/lb. He thinks he's lifting the heads.....I think not. At 20psi and 13 degrees....I don't believe he's making enough cylinder pressure to lift the heads. He's verified the timing with a light, so it's doing as it's commanded. The car runs good, went 6.29 @119 on 12psi......8.74 @155 running out of gear on 20.5psi. Personally I think it's a cracked sleeve, he thinks not. ..because of no water in the oil. My logic is, cylinder pressure will prevent water getting into the hole while running..... but will seal up enough to not leak in when shut off. Thoughts?
Old Mar 24, 2018 | 03:17 PM
truckdoug's Avatar
IME a cracked cylinder will weep water after shut off
how's he checking for pressurized coolant? symptoms?
Old Mar 24, 2018 | 05:05 PM
Game ova's Avatar
it's forcing water into the overflow and hitting 230 degrees. By the end of a pass.
Old Mar 24, 2018 | 05:27 PM
a05c's Avatar
Is there air bubbles in the overflow?
Old Mar 24, 2018 | 05:33 PM
Game ova's Avatar
He doesn't know, just ordered a catch can for the radiator. Couldn't tell with the factory one.
Old Mar 24, 2018 | 05:38 PM
Game ova's Avatar
Oh, and here's another thing. He pulled the plugs, and there's no signs of coolant in any of the holes. Even went so far as to pull the heads, every hole is fine. After he told me that, I was completely stumped. I could see if he was running big boost on 20 degrees, but as it is now..... it's just not adding up.
Old Mar 24, 2018 | 05:55 PM
stevieturbo's Avatar
has it ever ran correctly and reliably ?
What sort of pressures is he seeing in the cooling system and when ? If he cant log, just hook up a cheap gauge to a high location on the rad/header, preferably in air.
Old Mar 24, 2018 | 06:08 PM
Game ova's Avatar
He's had issues with the build ever since its been completed, which was about 3 weeks ago. With that said, it's the same block that he was using a couple of seasons ago.... just dropped in a junkyard motor in the interim till he could afford this big build. So it's just been sitting, but yes it was fine when he was running it....although it was just a heads cam car at the time. He hasn't logged coolant system pressure as of yet.
 Michael S. Palmer
Old Mar 24, 2018 | 06:15 PM
ls3fox's Avatar
7 Second Club
so he took it apart checked all the cylinders put fresh head gaskets in it and it still pushes coolant?
Old Mar 24, 2018 | 06:24 PM
As a new unproven build...it could simply be a bad cooling system arrangement, lack or airflow or indeed something engine related.
The fact the block has been used before without issue should at least give some hope that is not the problem
Old Mar 24, 2018 | 06:25 PM
Game ova's Avatar
Yup, went back with fresh gaskets... and it's still pushing water. This is what's making me lean towards a bad sleeve. But I have no experience with one that's split, so it's tough for me to say really, although truckdoug said his weeped in when he had one go bad.
Old Mar 24, 2018 | 06:34 PM
ls3fox's Avatar
7 Second Club
if it had a bad sleeve you should know pretty fast i broke a sleeve at 30lbs on my other car it put so much pressure in the coolant system it blew the hoses off . i would just go double check everything makes sure the t stat is good fans are working and are blowing the right way ive done that before turn the fan on and the car would get hotter and then just make sure its fully blead
Old Mar 24, 2018 | 06:54 PM
jimmyg's Avatar
Took a really long time to bleed my build . It was doing the same thing. Finally I filled it through the top hose and attached a lisle funnel and let it run forever while squeezing the hoses. Some are just harder to bleed than others, especially if it’s been all apart
Old Mar 24, 2018 | 06:56 PM
Game ova's Avatar
Agreed. I had that issue when I put mine back together. But with his setup, he's not running a tstat... so it shouldn't be as hard to purge.
Old Mar 24, 2018 | 08:00 PM
truckdoug's Avatar
anyone you know got a vacuum filler? i made it like 35 years without a cooling system bleed issue then I bought a ******* bmw and now all my **** has problems bleeding. ****** bmw cursed me man. bought the vacuum fill kit and **** is alright in my world once again.
Old Mar 24, 2018 | 08:46 PM
Bad Apache's Avatar
Buy a Lisle 75500 or equivalent combustion tester and confirm or eliminate whether it has combustion gases in the cooling system. They are cheap and readily available. If no gases, get/borrow the vacuum tool and fill it. No thermostat is not a guarantee the system doesn't have trapped air.
Old Mar 24, 2018 | 08:59 PM
truckdoug's Avatar
thats awesome. had no idea. ordered it.
Old Mar 25, 2018 | 07:57 AM
Bad Apache's Avatar
Advantages to being an Auto Tech for so many years. One other trick for everyone. The fluid (usually blue in color) changes to yellow or green in the presence of combustion gases. If you remove the tester from the area and keep pumping the bulb it will change back to blue and can be reused. I keep it in a separate container so I know it is used. But have had no issues reusing it.
Old Mar 25, 2018 | 08:01 AM
Game ova's Avatar
Thanks for the tip.
Old Mar 25, 2018 | 08:06 AM
rotary1307cc's Avatar
What block?
When my iron 6.0 cracked it didn't leak period water into the cylinder
It stayed completely sealed up unless it was under power then it would open up
You could drive around just fine with no issues or symptoms. Make a hit and you could push a gallon into the overflow in a 1/4 mile
It's tough to see the crack unless you are looking for it.
You can test for combustion gas in the coolant with a CO detector and a ziplock bag in 2 seconds
