LSA/5.3 in OBS C1500
Old Apr 27, 2018 | 08:11 PM
EspaceF1Fan's Avatar
Default LSA/5.3 in OBS C1500
First a note to moderators: if this post is in the wrong place please move it. I debated between here and hybrids/conversions.
Ill keep this short but I can elaborate if needed or wanted.
What I want to do: install LSA blower on my 5.3 using my truck accessories and probably the Holley ls ac compressor bracket for R4 compressor. I would be using a 6rib belt and the Holley bracket uses a 2000 c5 Vette tensioner
Goal: 550rwhp or better in a truck I can drive 1000 miles or daily drive it without fear of the belt drive letting me down.
Question: Will I be shredding belts, slipping belts or shattering the tensioner?
Any advice or experience is welcomed and appreciated
Old Apr 27, 2018 | 10:18 PM
ElQueFør's Avatar
Sounds like a cool project man. I have a turbocharged 6.0 in my OBS.... I love it.
I ended up using the LS a/c compressor and just notching the frame to fit it.
Don't know about the belt tensioner stuff since I'm turbo and not super but I don't see how it would be a problem. The LSA is a factory setup so prolly pretty bulletproof.
Old Apr 28, 2018 | 10:34 AM
The engine is already in the truck so I don’t have much interest in frame notching. Mostly for the idea if pulling engine if an accessory fails....
as for the factory lsa setup I would consider it IF I had a way to do electric power steering... but I don’t
additionally if I invest too much in accessories turbocharging becomes far more cost effective to the point it can’t be ignored.
Old Apr 28, 2018 | 03:59 PM
ElQueFør's Avatar
I had to pull my engine out many times when building it. It's just easier to mock up what you can and build that, then pull it again if necessary.
I don't have to pull the engine if the compressor fails, Just unbolt the compressor and pull it out.
I originally planned on using the R4 compressor. But the LS compressor is better anyways so that was my decision point.
I don't know about supercharging as I've never done that but I will say that I prefer turbocharging based upon what I know.
Supercharger will be instant boost but linear.
Turbocharger can have lag before boost (minimal to nonexistent if you pair your parts well) but the boost comes on exponentially, like a ******* avalanche.
