Fuel cut problems
Old May 14, 2018 | 08:05 PM
wachs1981's Avatar
Default Fuel cut problems
Ive had my turbo lq4 for about 3 years now. Hp tuners SD tune. 78/75 turbo, tick 3 turbo cam, studed 05 long block. Last week at the track after adding 4.56 gears, it was detonating bad on 15 degrees timing on 93. I dropped it to 13 and did better time, but detonating. I dropped it to 10 degrees and now I have a crazy fuel cut issue. Like the injectors turn off. Never did this before and now it' every time. 10 degrees seams to build boost way faster. I have 58 pound Bosch injectors on 55psi with a 340 lph pump. Any ideas.
Old May 16, 2018 | 07:08 AM
Old Geezer's Avatar
Ideas? For starters, log fuel psi, during the run.
