looking into cam swap
Old May 25, 2018 | 09:04 AM
User-c3's Avatar
Default looking into cam swap
just wanting a bit of input on cam suggestions and maybe someone with a similar setup can chime in with their cam specs. Need to tune for the heads so I may as well put in a better suited cam for the turbo than the stock 99 f-body unit.
currently stock bottom end 5.7 LS1
as cast 317's
PAC dual springs .660 lift
Trunion upgrade
Comp pushrods
ARP studs
LS9 gaskets
not looking for huge numbers, I run the car on road course and street drive it, so just something with a decent chop and better flow.
been thinking about the comp blower cam 227/243
any input?
single Holset HX55
Old May 25, 2018 | 10:10 AM
ss.slp.ls1's Avatar
https://shop.brutespeed.com/Brute-Sp...d-Camshaft.htm
^^^Here is one option.
Old May 25, 2018 | 10:21 AM
JoeNova's Avatar
Restricted User
An HX55 isn't a very big turbo, especially if you have the 65mm version.
You will want a much much smaller camshaft for it. Neither of those is a good match.
Old May 25, 2018 | 10:24 AM
ddnspider's Avatar
Without stating goals and seeing the turbo I'd go with something like a triple 12 or the 215 215.
Old May 29, 2018 | 08:59 AM
User-c3's Avatar
A solid 600-650 whp would be nice. As I stated before I use the car mostly for road course so I'm not looking for big straight line power.
I found this article where they used a stock bottom 5.3 and as cast 317 heads with the cam I mentioned above and made 691hp on 7lbs of boost
http://www.superchevy.com/how-to/eng...t-under-boost/
Old May 29, 2018 | 10:54 AM
ddnspider's Avatar
Thats a cool link. For road course or Auto-X you need mid-range torque to get out of turns. Keep the cam small and it'll drive better too.
