Supercharger differences
The Magnacharger works great on the street as a blower with instant boost and low end torque. The one I rode in feel like just as responsive as a normally aspirated engine. It had massive torque down low.
The ProCharger is more of a serious street/race supercharger. Typically superior air flow in the upper rpm ranges.
A friend had a Procharger with a blow off valve and throttle switch. His Procharger never built any boost just riding around because the blow off valve was open until he jabbed the throttle to the floor. In normal driving it was about as responsive as a stock LS1. It didn't have massive low end torque on tap. When he floored it, the throttle switch then closed the blow off valve and it built boost.. It was fantastic power braking at stop lights or from a dig at the track. Less so from a roll unless you wanted to ride the brakes and floor it.
That's my limited experience
In a impromptu stock vs stock street race from a roll the Magncharger would get the jump on the ProCharger, but the ProCharger would catch and pass him.
And its really nice with the Pos Dis SC'er......for install. You remove the intake and drop it on and bolt it down.....thats it. Very clean and easy. No pipes running all over the place. And you can make 900-1,000 RWHP with whats available for LS engines right now. And NO, its not that expensive....no more than the other SC'er set ups.
Nothing wrong with Centrifugal.....but when I personally weigh the pros and cons....its a no brainer to go with Pos Dis...especially for a street/strip car. But if someone wants a certain amount of power that the Pos Dis SC'er cannot offer for the LS engine right now......you have to go with a large Centrifugal SC'er. And those larger Centifugal SC'ers are FRIGGIN LOUD as hell just sitting still idling.....unlike the quiet Pos Dis SC'ers.
So its up to each person what they want and what they don't want......
