Average rwhp per psi on E85?
Thanks
Brian
To give you an idea of how much difference that can make: In my Subaru, 17psi with the stock turbo was good for about 260whp (stock power is about 215whp, so that's a gain of 2.6whp per psi), whereas the GT3076 that's in it now makes 22psi and 375whp (gain of 7.3whp per psi). Bigger turbos make around 450 with boost in the teens, so 12ish whp/psi. The same sort of thing will apply with an LS, except the whp numbers will be more-than-doubled because the displacement is more-than-doubled.
So, PSI numbers tend to be more misleading than useful. Be careful with them.
