24 0r 58 reluctor
Old Jul 24, 2018 | 05:34 PM
moms73's Avatar
Default 24 0r 58 reluctor
I am building a 408 and using the fi tech ultimate kit for the ls3 heads The builder asked if I wanted the 24 or 58 reluctor wheel I would like to use the 58 but I am using a 2004 6.0 iron block . I also know they moved the cam position sensor do to upgrades in the newer engine . So can I use the 58 and use the older style cam sensor together ?
Old Jul 24, 2018 | 06:18 PM
3 window's Avatar
Yep. You just need to replace the front cover with one for a front cam sensor. Crank sensors in the same spot on both.
Old Jul 24, 2018 | 06:24 PM
stevieturbo's Avatar
You can use any trigger setup if your chosen ecu is happy with it. In this case it is FiTech you need to be asking. But you can get both 1x and 4x wheels for the front so it really shouldnt be a concern either way, just find out what your FiTech wants.
Old Jul 24, 2018 | 07:38 PM
8.Lug's Avatar
Higher resolution is always better so no sense in running a 1x cam and 24x crank if you can run a 4x and 58x without any extra work.
Old Jul 24, 2018 | 08:01 PM
From a trigger performance point of view, 1x or 4x on the cam really makes little odds. But the 58x crank is a better wheel/design.
either way, you need to keep your ecu happy.
Old Jul 25, 2018 | 01:52 PM
pantera_efi's Avatar
Default GM 58x (60-2) AND 1x CAS = OK
Hi ALL, I OFTEN fit a 1x CAS WITH the 58x TW. (NON GM PCM)
The "1x" only needs to report AFTER the last cylinder AND BEFORE the first cylinder, this sets engine Phase correctly.
Lance
