What size twin turbo?
Old Jul 31, 2018 | 09:52 AM
Ws6ls's Avatar
Default What size twin turbo?
Im looking forward for your opinion on which turbo size would be best for my aplication. I have a ls1, 243 heads, ls6 intake and Im gona get a turbo cam yet. But Im at altitude 8-10k da, so I need something that doesn’t run out of steam. My goal is to make 1000whp corrected.
Old Aug 1, 2018 | 11:48 AM
Luke19901's Avatar
twin 66/67 precision
twin gt3582 garret
SXE 62/68 BW
or similar will easy do it
Old Aug 4, 2018 | 02:08 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If you are dead set on doing twins, good luck,, but your goals will be easier and far cheaper to achieve with a big single. Twins have a tiny spool advantage and a massive plumbing disadvantage. Sometimes packaging takes the choice out of your hands, but otherwise you should go with the easier plumbing.
Old Aug 4, 2018 | 10:47 AM
Ws6ls's Avatar
Im not gona build the kit myself, I have a fbody ws6 01, and its gona be a twin turbo huron speed, the big turbo kit costs just as much but I need the tiny bit of spooling advantage at altitude because you have no idea how much it sucks to have a turbo and not being able to spool it right. Plus it takes 2 wastegates in the single as well, needs the radiator stand up so all said and done with a bigger turbo cost vs 2 smaller ones it goes out to same price, but what you said about all the pipes thats something Im not looking forward to lol
Old Aug 4, 2018 | 03:51 PM
stevieturbo's Avatar
arguably of all of those the 67mm Precisions will move the most air.
Garrett...overpriced and underperform
BW...there is a much wider range of units than just what you've stated to choose from...why not something more comparable to the Precision for size ?
And poor heads, no mention of trans, fuel, etc etc and hoping for 1k at altitude ? And is the LS1 otherwise stock ?
I think you may need to consider more than just turbos and a cam here.
Old Aug 5, 2018 | 08:36 AM
Ws6ls's Avatar
Has forged internals, fuel E85, 4l80 , jakes performance 3d billet 10.5 TC
