Let's talk backpressure vs boost
People have been putting twin 3" exhaust on stock standard V8s for decades and making increases in power. On stock NA engines.
The 8psi backpressure is absolutely correct, not an error, and is extremely high.
For future reference here is an online tool I have used for years to calculate exhaust pipe diameter. I find it to be accurate. https://www.mk5cortinaestate.co.uk/calculator5.php
Spoiler: you need 4" at least
My car has a single turbo,meaning I cannot run a true dual exhaust because each manifold/header must merg..or come to a Y pipe to feed exhaust into the 1 turbo.And then exit said turbo from its single output which is a 3" vband flange.
So iirc Customblackbird has a very near identical setup to me in the same car but when i first set out to try turbocharging my car as mentioned I was making 400whp.My goal was to add 100-150whp..maybe hit 600whp on a cool dyno run. I did this on the cheap before cxracing offered a turbo kit for our cars that has more potential than my custom setup and heres why I think so. Im using flipped truck manifolds that are welded to a 2.5 merge pipe vs the cxracing turbo headers that have a better flow out of the heads into the turbo.This only complicates my exhaust issues for backpressure on the high boost side of things.At the sametime..the truck manifolds with the 2.5 merge does help spool quicker than a larger header.there are pros and cons to this.
I can easily just run the car at 12psi and not even worry about things and leave all else alone and have my existing cutout open and make low 600whp.I just cant go back down to that power level after tasting 15 ..18 20psi in my car as it sits..wanting to make more power safely if it could diarrhea **** itself fast enough! All i can do is try to aid the existing down pipe with another bypass much closer to the turbo itself and have a 2.5" fender exit on a loudvalve and then the rest of my exhaust setup and cutouts handle everything else.After that..if I the car still isnt happy enough I could try changing mufflers but I feel that the muffler is so far down the chain that with 2 cutouts in a very straight piped system before the overaxle isnt affecting much.
The main concern isnt power for me at this stage guys,thats not the point of my thread..its the concern of how bad the backpressure if I continually run high boost having 8psi backpressure is shortening the life of my motor power..which in affect is robbing me of extra power i havent felt yet.I was very content at making 650whp on 94 pump gas at 15psi till that motor popped at the track due to my neglect at the track on a hot day forgot the turn on meth and made a high boost first pass out the gate.
The car goes in the shop next week for the fender exit. Which Im doing a few add ons like having a lip welded ontop the tb so my charge pipe stops slipping off,upgrading to a newer faster cutout,install line lock,and then start using 30/70 water/meth at 20psi and see what the dyno tells me and what the backpresure equates to.If there is any backpressure still..slowly back off the boost bwteen 15-20 where the backpressure is in a tolerable range and Ill call it good and thats my final high boost setting from here on out
All else fails..Ill have a boost activated fender exit exhaust to shoot flames at cars while at a light hitting the 2step and just have fun with the car like I normally do on the streets and highways.I never intended the car to make over 600whp and its now costing me to make everything else on the car handle what its putting out.
Are you trying to make "high boost" because you like big numbers on a boost gauge, or are you trying to make horsepower? You may find that reducing exhaust restriction allows you to make the same power at lower boost pressure, which is almost certainly going to mean lower EGTs, lower pre-turbo backpressure, lower IATs without methanol, faster boost response, etc. Even if you are using a turbo with a 3" V-band, the fact that you are seeing 8 psi post-turbo would tend to indicate that there is something you can do to reduce restriction after the turbo. You may find that doing a short dump or cutout right off the turbo may make a noticeable difference. I didn't want to do that, so I went with a setup where the downpipe spreads out to 3.5" as quickly as possible and then splits into dual 3" as soon as there is room. Overkill, probably, but it clearly worked.
You should notice a big improvement.
So the exhaust shop that fabbed my turbo kit did a solid job on making my fender exit loudvalve.Its on a vband and flex pipe and fits quite perfectly.I got sent this pic on Thursday when the show owner called me to confirm if I wanted a bezel around the hole or not.And that everything was done very cleanly and if i was going to hook up the lines and wiring myself.
I was excited to see it in person,get it home and hookup the loudvalve.I knew if I had it working on the drive home when I picked it up..id get into trouble since its a hr drive and lots of law wouldnt be happy to see or hear that thing in action.After picking up the car and talking to the shop owner and other customers there asking about my ratty looking bird that has a crazy setup underneathe.I cruised home,got some vacuum line and hooked up just the loudvalve,didnt jack the car up yet to wire in the new 4' e-cutout and see how it was re-worked for better flow.
I backed out the driveway and started driving,I could hear the turbo spool up quicker and crack the valve open around 3psi and it was snappy. i did a few short pulls and it was lighting up tires and generally felt much happier. I found a spot and wanted to see for ***** n giggles if the 2 step had enough boost pressure to crack open the valve and maybe shoot flames..but it was having it. My tuner is anxiuous to see when we can strap the car back down on the dyno and measure any gains in power..and what the backpressure reads with the cutout and loudvalve helping release.butt dyno says its loving the ability to exhale. Check out the video and hear the turbo response.
The work looks great, nice TIG welds and SS.... makes the rest of your hotside look like poo man lol.
You decided on the 2.5” how much boost we’re you pushing? And what loud valve did you end up going with? I don’t like
not being able to keep it from opening for more stealth pulls but since it opens with boost its still not helping with the pre boost spool up that the electric cutout being manually
open would provide.
Overall i I think your going to be surprised with what you pick up
I went with the 2.5 due to packaging and honestly its perfect size to snake in the way he did. If I had the cash,with the wheel liner remove..he offered to make the exhuast come out of the factory fender vent and make it completely stealth.That could be a future iteration.
The test runs I can hear it cracking open around 3psi. If i feel that I want it to open later then I would just use a manual boost controller to set it higher for maybe 10psi. The electric cutout is positioned better as a primary dump while open and its a larger diameter.Having both open and going for a high boost run I definitely feel it running harder.Very curious to see if it made a significant increase in power or just holds a steady topend. Time will tell.
