Vortech V7-Ysi project on L96
Old Aug 7, 2018 | 12:20 PM
bodomram07's Avatar
Question Vortech V7-Ysi project on L96
Hi all,
I decided to go with a Vortech V7-Ysi on my L96, here the parts I want to order
2A158-070 V7-Ysi , CCW, curved discharge
4GX110-064 Mounting Bracket
4GX116-020 Drive assembly
4GR100-110 Damper Pin Kit
My engine is stock for now, other than the Comp Cam and ARP Rod Bolt, I use Fitech 750HP Ultimate LS Kit
I do not plan to run this with and aftercooler for now, and want to limit boost to 10 psi
What's your suggestion for overflow valve ??
Thanks
Old Aug 7, 2018 | 05:53 PM
stevieturbo's Avatar
what are you expecting to overflow ?
Old Aug 8, 2018 | 12:35 PM
bodomram07's Avatar
I want to limit the V7 output to my L96, since the engine is stock, I ma planning a full forged setup in 2-3 years
Old Aug 8, 2018 | 05:11 PM
So just fit pulleys that will generate 10psi boost....simple
Old Aug 10, 2018 | 08:46 PM
bodomram07's Avatar
Stevie
Is there a site or a chart where I can find the pulley size ratio for the V7 ?
Old Aug 11, 2018 | 05:19 AM
pulley size ratio ?
Do you mean the internal gear step up up or something else ?
