Building a LS 408 Stroker Motor
Old Aug 8, 2018 | 07:18 PM
Robert Pickett's Avatar
Arrow Building a LS 408 Stroker Motor
Im building a 408 Ls stroker motor with 8 pound ProCharger Turbo 350 Transmission with 3500 stall and Ported Cathedral Heads, 4:10 Gears
Would like to run 93 Octane gas so I can drive it on the street? I need help on what and whose Cam size I should use and what compression Ratio I should go with?
Old Aug 8, 2018 | 07:50 PM
King23's Avatar
Honestly i would call up a vendor when your ready to order a cam i have had 3 different cams from 3 different vendors for different builds and they was all great and as far as compression around 10:1 would be pretty healthy.
Old Aug 8, 2018 | 08:17 PM
Busted67's Avatar
Th350 will not like a charged 408.
Old Aug 9, 2018 | 09:25 AM
transam69230's Avatar
I wouldn't build a 408 either, too much stroke.
Old Aug 12, 2018 | 08:56 AM
stevieturbo's Avatar
Dont necessarily need the stroke, 4.1 gears will be bloody short...and you've given no power goals, nor even which blower you want to use. Nor any details of the engine itself, or fuel you intend to use..
Give details.
