Looking for a 1K HP Fuel System.....
What is needed for fuel pump, and injectors?
I'm not sure if a walbro 450 will get the job done, and not sure about the snake eaters injectors. I want something that is affordable, and I don't want to have that thought of if or when will the injector fail.
This will be a daily for the most part, needs to be reliable.
This will be a 3500lb, car.
Thanks.
Just some back-of-the-envelope estimation seems to suggest that you need at least 100 lb/min fuel injectors to make ~1200 crank horsepower on ethanol, and you'd nearly be driving those static, so you'd probably want 120s. You'd need nearly 600 lph of fuel pump to comfortably support that much fuel flow, and you may need to oversize a bit past that if you intend to run a 4-bar base fuel pressure.
