Injector issues
Old Oct 4, 2018 | 06:20 AM
Chazda's Avatar
Default Injector issues
Injector issues [QUOTE]
I have a 5.3 running e85 and 17lbs of boost with 80lb injectors. I had 2 go bad so I ordered a new set. Now it runs lean at idle or cruising speeds but when I get on it it runs ritch😤😤😤 so I bought hptuners but I'm lost I have no clue where or what to adjust. Is there anyone willing to guide me through this please
Old Oct 4, 2018 | 05:55 PM
Drj8787's Avatar
I assume you bought the same injectors. Do you already have hpt or are you waiting for it to arrive? Once you have it in your possession you will need to post the tune file some logs and the config. Otherwise you will be hard pressed to get any feedback.
