log manifold and o2 sensors
Old Oct 10, 2018 | 11:38 AM
first5.3t's Avatar
Default log manifold and o2 sensors
Thoes that are running a turbo log manifold. What is the suggestion on running o2 sensors, drivers side bank will see what's going on but not the passenger... is this how a log system works when running o2's or should I just go speed density and not mess with the sensors and just use a wide band?
Old Oct 10, 2018 | 12:25 PM
truckdoug's Avatar
I do speed density closed loop and I like it a lot. It helps tame rowdy cams, big injectors, my crappy tuning and fluctuating weather
you can do one NB on each side preturbo. Thats how ronSSnova does his and it works awesome. runs 8's on a shitty track, pulling the tires out of the hole.
I personally do a single NB post turbo and wye a single sensor to feed both "banks" of the sensor wiring. It runs really good, albeit not that fast lol
