Help With A IGN Problem
Old Oct 27, 2018 | 01:18 PM
Driver2's Avatar
Default Help With A IGN Problem
This will be long to explain the problem! I have a 1998 F-Body 6.0 LS truck engine with a 80BW turbo car was tuned by Los Vasquez out of Florida which car ran fine then two weeks ago it just started cutting out and missing and dies. Starting from the beginning of the build! When i ran the wire from the the solenoid to the IGN wire (pink) it would start up as soon as i touched the wires together so I ended up using the yellow which i think it is the(acc wire) anyway it worked but when it started missing and cutting out that was the first thing that came to my mind. The other odd thing is the kill switch wouldn't kill the car so i bought a new Moroso switch and it worked just fine but now it's not killing the car all the time but other times it will. I double checked and yes its hooked up the correct way. I bought this car off of a guy that had a 305 small block in it and all the computer stuff he had already taken out and I'm not sure what all he did. Ive checked the plugs and wires and everything is good there. (They are new ) Took injectors and cleaned them and found nothing wrong there. Im stuck on this IGN problem thinking the problem is there? Anyone have any ideas?
Old Oct 28, 2018 | 03:27 AM
Driver2's Avatar
Well can someone tell me if u ran the wire off the solenoid and tied into the pink wire ?
Old Oct 28, 2018 | 09:01 AM
jimmyg's Avatar
Old Oct 28, 2018 | 11:46 AM
Driver2's Avatar
Thanks
