Ring gap on stock 5.3
Old Dec 26, 2018 | 08:23 PM
Elcodude85's Avatar
Default Ring gap on stock 5.3
im just curious on what people are gapping their rings for a boosted 5.3, I have a cam and springs for this motor and other than that it’s stock (sloppy mechanic stage 2 cam and pack 1218 springs) . Just wanting to do a little to this motor while I build a motor. Thanks I’m advance!
Old Dec 27, 2018 | 08:46 AM
80/TA/LT1's Avatar
26 top 28 bottom here
Old Dec 27, 2018 | 08:32 PM
sbdgbody's Avatar
.028 top second .030
Old Dec 28, 2018 | 07:14 AM
epfatboy's Avatar
How much boost? Also check the OE gap, I have read countless threads about this and many say the gap for stock is like 26/28 which will be fine for around ~16 psi
Old Dec 28, 2018 | 07:50 AM
Elcodude85's Avatar
[QUOTE=epfatboy;20021944]
Right now I’m at 9-10 pounds but I’m installing a boost controller this weekend and gonna do 15 pounds max for this motor anyway
Old Dec 28, 2018 | 07:53 AM
epfatboy's Avatar
I'm doing roughly the same build as you and left the stock ring and gap.
Old Dec 28, 2018 | 06:30 PM
sbdgbody's Avatar
epfatboy whats your ring gap did you check it ?
Old Dec 28, 2018 | 07:38 PM
epfatboy's Avatar
was gonna but decided to send it as is,. what's the worst thing that can happen right...
Old Dec 28, 2018 | 07:45 PM
Lsx Rubi's Avatar
My experience so far stock gap 2006 4.8 top .018 bottom .024 , 2008 5.3 top 0.24 bottom .026 , 2003 6.0 top .020 bottom .026. So it was different for all of them , I would check them and open them up .026-.28 if you plan to push 600-700 whp.
Old Dec 28, 2018 | 07:50 PM
Game ova's Avatar
Will come apart soon....
Old Dec 28, 2018 | 08:40 PM
brandon6.0's Avatar
Most higher milage motors already have a almost perfect ring gap for boost. Usually around .026-.030
Old Dec 28, 2018 | 09:07 PM
DBRODS's Avatar
28/30 for 40psi on a 5.3 is no problem.
Old Dec 29, 2018 | 08:24 AM
epfatboy's Avatar
I was thinking more like window the block, oil down the tires, and be upside down and on fire.
Old Dec 29, 2018 | 08:43 AM
DMarts10's Avatar
Gap your rings kids
What happens when you don’t gap your rings and boost a stock ls1 to 16 pounds on a highway pull. All 8 looked like this...
Nothing happened btw. Car stalled, didn’t lockup or anything. Just massive blow by. I popped in the clutch and coasted to the nearest off ramp.
When I pulled the heads off the bottom end appeared fine. Tops of the pistons were intact and the cylinder walls looked pristine. It wasn’t until I pulled the oil pan that I saw the carnage.
Old Dec 29, 2018 | 01:13 PM
Stonerracing's Avatar
When u gap the rings do u recondition the rods or just put the same bearings back in. My concern is the egg shape that can form on high mileage engines.
Old Dec 29, 2018 | 01:16 PM
Luke19901's Avatar
that aint ring gap causing rings to bind up.....
that's det. rattle so hard the ring lands get blown off.
that's impressive! would love to see some IAT, AFR and timing data and know what fuel
Old Dec 29, 2018 | 01:17 PM
Luke19901's Avatar
measure your rods with precision measuring tooling. it will tell you if they have out of round bores or bushes and if they need reconditioning
Old Dec 29, 2018 | 08:04 PM
Elcodude85's Avatar
this motor has 212k miles on it. I towed it to the junk yard and it ran and drove
Old Dec 29, 2018 | 08:05 PM
Elcodude85's Avatar
Not yet, I’m gonna pull it apart Monday
Old Dec 30, 2018 | 06:50 AM
epfatboy's Avatar
no im not
