Fuel pump for bypass regulator
Old Jan 6, 2019 | 10:38 PM
Stonerracing's Avatar
Default Fuel pump for bypass regulator
I bought a pro systems bypass regulator for my blow through carb. I was wondering if the a1000 would be a good pump to use with it. It says its 150 gph. I wasnt sure if i run a bypass setup if i need a higher gph fuel pump. Or just go back to a deadhead regulator. The motor is an on3 78/75 turbo on 5.3. 650 csu carb. Thnx
Old Jan 6, 2019 | 11:31 PM
LLLosingit's Avatar
The regulator doesn't care what pump you run unless the pump is so powerful that it pumps more fuel than the regulator can bypass.
Old Jan 7, 2019 | 05:10 AM
The fuel pump that normally goes with that regulator is a 440 gph.
Old Jan 7, 2019 | 06:50 AM
LLLosingit's Avatar
The fuel pump should match the fuel type and amount fuel the engine needs, To big of a pump will needlessly heat up fuel and to small will run the bowls dry.
The regulator is there to regulate pressure not volume.
Old Jan 7, 2019 | 07:45 AM
JoeNova's Avatar
Restricted User
Having seen a pro systems 440, I have a really hard time believing it flows 440 GPH, especially through an 8AN outlet at low pressure. That's over 4000 horsepower worth of gasoline, or a gallon every 8 seconds.
Old Jan 7, 2019 | 10:48 AM
47ford's Avatar
Ran a1000 on 6.0 blowthrough 750 for three years with no problems
Old Jan 8, 2019 | 07:27 AM
forcd ind's Avatar
Same here
