4.8 lsa head swap test
Old Jan 14, 2019 | 01:51 PM
denmah's Avatar
Moderator
Default 4.8 lsa head swap test
I did a head swap from what most people would consider a really good cyl head, the stock 799's as they had exhaust valve seat pitting, wich is fairly common, to some dirty old 862 heads from 2002 4.8 i had laying around.
dropped them on and picked up almost 40whp up top. funny considering the intake valve is smaller, but the head chamber is also smaller
it raised my compression from 8.8:1 to 9.53:1
it was an interesting experiment to see if it would be a push or worth it.
food for thought a hellcat makes 640whp on my dyno
Old Jan 14, 2019 | 02:07 PM
JoeNova's Avatar
Restricted User
I've been trying to tell people for years that head flow on a boosted 4.8 or 5.3 is completely irrelevant. Thanks for this.
Old Jan 15, 2019 | 09:57 AM
Bad Apache's Avatar
Not busting your chops. I really appreciate what you have done for the automotive community. But that test isn't very accurate. The"good" heads had leaking valves. And you said it makes another 1-2psi of boost as a result of the changes. But we always appreciate the honest data anyhow!
Old Jan 15, 2019 | 11:05 AM
SLOW SEDAN's Avatar
At relatively low power or a setup that's not maxed out I agree 100%, under 1000hp on most setups you can easily turn up the boost and save the money. But when you're already at 35+psi on the largest S400 offered and you are looking for a few more MPH aftermarket heads are a viable option if you don't want to completely rework the turbo kit or build another engine. You can take that 1200 hp or so limit of stock heads chucking gaskets and bump it up to 1400hp or more keeping the heads down. Between a turbo upgrade to S500 or GT55, bigger engine, or better flowing heads in some cases a set of TFS heads is the cheapest option and we did see them perform, easily picked up MPH on less boost.
That said I too went from 317's to 862's on the same setup and picked up a few MPH on the same boost, but was still 5-6MPH down from the aftermarket heads.
Old Jan 15, 2019 | 11:36 AM
JoeNova's Avatar
Restricted User
Extremes always create exceptions.
Old Jan 15, 2019 | 11:55 AM
Hank Peabody's Avatar
That car turned out really nice Matt! You should run it at a half mile or mile race, perfect for it! I ran my bike at the Texas Mile last year and while the turbo blew up and took a dump and never got a good result it was a lot of fun and very laid back.
Old Jan 15, 2019 | 01:10 PM
1FastBrick's Avatar
Have you driven this combo on the street yet? I am curious to see if you have an issue with lean tip in as some have reported.
Also, Was it actually pitting on the valve seats or cracked in between the seats?
Old Jan 15, 2019 | 05:26 PM
BCNUL8R's Avatar
I went and watched your youtube video on this... I'm shocked that the 862 heads actually made slightly less down low, but made a lot more up top. Can someone explain how this happened? Maybe the 799's with issues actually are what caused them not to perform as well up top? Not a criticism at all as no one is really doing these type of comparisons, but I'm seriously interested in learning.
 Michael S. Palmer
Old Jan 15, 2019 | 07:00 PM
Stonerracing's Avatar
Its called coefficient of discharge. Flow numbers are down the list for importance of cylinder heads even though thats the first thing everyone looks at.
Old Jan 15, 2019 | 10:06 PM
TT427's Avatar
Hey Denmah, do us a all a favor and notch the bores like the BBC did next time you throw big chambers/valves on a small bore.
Old Jan 15, 2019 | 10:49 PM
Lsx Rubi's Avatar
I agree but the majority of the people are not shooting for 1000+hp , yet on this forum everybody always recommend to swap to 799 heads to gain that extra '50hp' on sub 600-700 hp setups and ditch the garbage 862s .
Old Jan 15, 2019 | 10:50 PM
Lsx Rubi's Avatar
Those are some really good numbers for such a basic and daily driveable setup
Old Jan 16, 2019 | 03:52 AM
BCNUL8R's Avatar
This video shows it isn't a fair comparison because there were obviously issues with the 799's...
Old Jan 16, 2019 | 08:30 AM
badass68's Avatar
Not to mention adding compression does the same as adding boost.
Old Jan 16, 2019 | 08:49 AM
BCNUL8R's Avatar
I bet you add a lot of compression when you can’t see day light between your exhaust valve and the seat...lol
Old Jan 16, 2019 | 09:46 AM
SLOW SEDAN's Avatar
Right! lol
Agree, zero reason not to use 862's at that level or higher. I've given the 862's hell and they took it all. I ran 8's on 862's they still looked perfect so slapped them on another engine to do it again. I did try some ported 799 heads which worked well but basically it was just the same power at slightly lower boost, I dont care about boost level so didn't mean much to me. To do it again I'd skip the ported stock head step and go straight to TFS with a thicker deck, only a $500-600 difference that will take you much further.
Old Jan 16, 2019 | 11:06 AM
Kfxguy's Avatar
How is this even a valid comparison? leaky valve heads vs a non leaking valve head. Am i missing something?
Old Jan 16, 2019 | 11:31 AM
truckdoug's Avatar
maybe the part where his compression tester died and was giving him the same 50psi on the new heads?
Old Jan 16, 2019 | 11:56 AM
Kfxguy's Avatar
Lol what about the part where he said he could see daylight between the valve and valve seat?
edit. This video. Fast forward to 1:16
Old Jan 16, 2019 | 11:58 AM
3 window's Avatar
It’s not and you’re not.
