Truckdoug's turbo g-body malibu, now with more money lit on fire!
#226
i doubt it. I seen your paint work. with tig everything slows down a bit so you can concentrate on heat input and travel speed more easily.
with mig there's a pretty narrow range of acceptable travels speeds and torch angles for a given welding current. it either works or it don't and you have to change the settings
finally got a major blockage out of the way and installed the anti-roll bar
you can see the beginnings of a fuel system if you squint really hard lol
also I've been looking for wide 6-lug steelies for my '66 c10 for years and finally found a set so I know what project i'm jumping on next.
air ride, steelies & whitewalls, small turbo, manual trans parts hauler
#237
yeah it'll go through a couple cheap mufflers and dump in front of the rear tire. I did something similar on my blue squarebody and it was great...I could get my wife to ride with me occasionally
i have many karmas to repay in regard to noise pollution....straight piped rx7 at one point in my youth lol
#239
#240
Is that an aluminum driveshaft from a truck? My buddy has one from a 4l60 truck.
And what Yoke did you use?
I impulse bought an 84 Cutlass so this thread went from cool fab to a perfect example.
