Truckdoug's turbo g-body malibu, now with more money lit on fire!
#101
I tigged the axle to the center section, 309L rod is my preference. preheat by setting it atop my woodstove and getting a rager going. I put the weld in 1" at a time skipping around the tube like I was tightening lug nuts. thats my go-to technique for welding any steel to cast iron
but, I know people just go at it with the mig no preheat just .035 hard wire burning in as hot as possible and I never hear of failures so pick the one you're most comfy with i guess
#104
I've done a few 8.8 swaps for customers now and all of them have been out of alignment minimum 1/4" and I have to throw a come along on it to even get the bar in
All have been very straight when they leave but I'd like to see one after a couple seasons of launching on sticky tires
#105
#107
so I know it's not car stuff, but I just moved to new digs and I'm readying my workshop
take a look at my erection
the roof in my shop has a weird semi-cathedral construction...it has a ridge beam and rafter main support, but also has battens and ties....well it must have bowed at some point and the PO put a vertical post in the middle of the beam. That ate up a bunch of room so I added a joist and a couple slip block diagonals
like so
other side, added that light fixture too
then with the vertical gone I could perform my penetration
8" double wall stainless rockwool packed chimney pipe thru the roof, normal stove pipe to that
2' above the highest point of the roof, with a vacuum type cap so I dont get fucked by high winds out of the Columbia River Gorge
like so
#108
I have a wood stove besides the forced air oil furnace (free firewood, offsets price of oil, lol) and the
wind can cause problems. Need to look into that type cap. I def cant use it if painting, dam fan sucks
it back down the chim. no matter how much venting I do, and its in a diff section.
The things we have to do for winter builds, lol.
#110
nah it's the cast 75mm compressor wheel, with the small turbine. I'm hoping it does well with the 4.8, loosey goosey converter and 3.73's
i got so much work to do on my garage and shop first, then a couple large scale paying gigs...i'll be surprised if this thing fires by may
I can say for sure though the billet s480 with the 96mm turbine is incredibly powerful for the money. less than a dollar per horsepower in my experience
#111
I think I'm gonna do the same, cast s475 small wheel. I think it'll be plenty to get me in the low 6s 1/8 mile. Should be loads better than my current clapped out on3 7665, which runs pretty good really lol
#112
short update.
been steady collecting parts. bought a used holley (BARFFF) turbo log to save time since I seem to be short of that lately. 10 pt cage from some roundy round parts house. manual master cylinder kit. found a clean dash pad for a hundred bucks.
turns out the "built 355" is a smogger 305...listed it for 500 engine and trans with all the gaudy edelbrock crap on it on the trailerpark of the internet...craigslist. we'll see if the tire kickers come thru.
got almost all the wiring done for the garage and shop. wow 6/3 wire is ****** expensive. hopefully that's buttoned up soon so I have have my zappers back in action.
currently trying to get this miata NB rebuild done asap since dude's first race is march 1st
