procharger air collector box
Old Jul 10, 2004 | 04:16 PM
Blown Ta's Avatar
Default procharger air collector box
anybody have the optional metal procharger air collector box that you want to get rid of
thanks
e-mail
armendm@aol.com
Old Jul 10, 2004 | 08:54 PM
BOOSTAT4500's Avatar
A little heads up. Try one on your car before you buy one, and check the tune with it on. My car would not tune correctly with it. Something with the design was causing turbulence that was messing up the maf readings. I had to switch to a plastic box and everything was fine. I also had to install a second by-pass valve on the passenger side I/C. so my car is a little odd in itself. Your car might be different though and it won't cause you any problems.
Old Jul 10, 2004 | 08:58 PM
slow's Avatar
I have a painted one, its part of the intercoolers i will be selling soon, but i could entertain a trade + cash if your plastic one is good
Ryan212@aol.com
Ryan
Old Jul 10, 2004 | 09:31 PM
Blown Ta's Avatar
the only reason i wanna change it because the plastic one expands on hot days, i've seen it when i reved the engine today it was like 90 degrees outside
