TT drain help
Old Feb 10, 2019 | 12:42 PM
Jfrench4686's Avatar
Default TT drain help
I’m doing my first LS build let alone twin turbo build but I’m in the planning stages for my drains. I see plenty of information about single turbo drains. Also I see the front covers on summit/jegs with two drain AN fittingsalready on the front cover.
I have already purchased my “stock style” front cover and have a Holley oil pan for clearance into a first Gen Camaro.
My question is do I need a dedicated drain for each turbo? Or could I get away with a T fitting of some sort to drain into the pan via a single fitting.
Old Feb 10, 2019 | 12:50 PM
Dimeomboost's Avatar
I don't use tees for the drains just to be safe. If u don't have a welder for aluminum just drill and tap your oil pan on each side above the oil level. If its below it wont drain. I use a -10 off each turbo going straight down to pan or drill hole and use two bulkhead fittings with the nylon washer but the tap method seals better to me
Old Feb 10, 2019 | 03:38 PM
47ford's Avatar
Holley makes a pan for first Gen Camaro with turbo drains on each side now
Old Feb 10, 2019 | 04:28 PM
Damn it! I didn’t know that. Wish I would have known.
just looked at them, they look great too. Thank you for the reply
Old Feb 10, 2019 | 04:29 PM
yea I don’t have a welder for aluminum, however that’s the route I’m going to take. I already purchased the 10an bungs, going to take it to a local metal fab shop and see if they’ll weld it up for me.
Thanks for the reply.
Old Feb 11, 2019 | 09:29 AM
JoeNova's Avatar
Restricted User
I merge my drains with Y fittings. I even drain them below the oil level. Never a single issue.
