Vrx4 alright for boost?
Old Feb 11, 2019 | 09:49 PM
Skeet Skeet's Avatar
Default Vrx4 alright for boost?
Alright guys, here’s the quick run down. I have a 4th gen with the factory ls1 that I installed a vengeance racing vrx4. I recently purchased an Ls2 that I’m rebuilding with a stock bottom end that I’m going to put a Huron speed singl kit on. The specs are 228/230 .588/.592 112 +4 lsa. How do you think this will work with the turbo? I’m trying to save money where I can and figured since I already have the cam I might as well try it.
Old Feb 12, 2019 | 08:26 AM
svslow's Avatar
Yes it will be fine.
Old Feb 12, 2019 | 09:33 AM
David@Vengeance's Avatar
Especially for the boost/power levels that you'll be seeing on a SBE combination, the VRX4 or most any camshaft for that matter will work just fine for you. Thank you for running the cam and let us know if we can help you further in any way!
Old Feb 12, 2019 | 07:55 PM
Ok thanks for the quick reply. I’ve been running the cam for probably close to 6 years now without a hick up. I love the driveability and lope at idle. I’ll update once I get it done.
