VSracing s475 drain flange ?s
Old Feb 16, 2019 | 08:52 PM
Lsxford's Avatar
Default VSracing s475 drain flange ?s
Hey guys,
finally pulled the trigger on a new turbo. Went with the VS cast s475 t6 job. Have some questions regarding the drain flange. It appears the oil feed is just 1/4 npt which is easy enough.
but the drain, I am wanting to run a 10an because that is what I have. I found some on eBay super cheap, but it says it works with s200, s300, and s400. But the kit from other places only says s400, and it looks to be more round. Where the s300 flanges look square.
can anybody point me in the right direction?
do the s200, s300 and s400 use the same drain flange or is the s400 unique to itself?
and then is the VS the same as the genuine Borg? I would assume so but I know how clones are.
for reference I currently have an on3 7665, it looks like the flange from it won't work. I wish it would tho, would save me a few bucks lol
Old Feb 16, 2019 | 11:08 PM
truckdoug's Avatar
yeah use the ones for t6 framed turbos that use like 1/2npt
you can fit an absolute unit of a drain on those *******
Old Feb 17, 2019 | 08:59 AM
Teddy-2000RS's Avatar
The VS and Borg share the same drain flange type. Like Doug said the s400/T6 flange should work for you , I used the LJMS but the standard ol' amazon/ebay ones should work fine.
Old Feb 17, 2019 | 02:46 PM
Lsxford's Avatar
Thanks guys, got some ordered up. Can't wait to get this new set up smoking
