Maggie Tb upgrade
Old Feb 17, 2019 | 12:34 PM
ls1adamls1's Avatar
Default Maggie Tb upgrade
Hey all,
been a while since I’ve been on. I currently have a 04 gto M6 with a TVS 1900 SC. Stock heads and cam. Running shorty headers.
Move been kicking around the idea of going to a 92mm Tb with larger MAF and larger intake tube.
Would it be worth it?
also I recently took off my catless mids and installed my catted mids, the car feels like it picked up torque and pulls harder. Is this common?
Old Feb 19, 2019 | 09:12 AM
hellbents-10's Avatar
Yes anything you can do on the intake side is very helpful on a PD blower. You will likely see 1-2psi boost increase and 40-60hp.
Old Feb 21, 2019 | 10:01 AM
$$$$'s Avatar
Thumbs up
From what I've seen it should be a solid gain, curious to see some results though.
Old Feb 22, 2019 | 08:12 PM
old motorhead's Avatar
Check to see if you have any vacuum between the throttle body and the blower at WOT. There should be a port there. If there's little to no vacuum there, you're wasting your money going to a bigger throttle body. If you have 3" or more like I had on one of my builds, a bigger throttle body is easy hp.
