Pro charger d1x
Old Feb 21, 2019 | 08:03 AM
lawrenq's Avatar
Default Pro charger d1x
I'm kicking around the idea of building a boosted 434 to go in my 71 Chevelle. It's an erl sleeved ls2 block with a 4.155 bore x 4.00 stroke, compression will be around 10.1. I have both a stock ls7 and ls3 topend that I can use. I'm not looking to chase numbers, but I'd be happy with 600rwhp. I was originally going to build a high compression N/A engine with aftermarket heads, intake, etc. But after adding up the costs, it's not much more to build a boosted engine.
I know that I could reach my goal with a smaller engine but this is what I have. The car will be mostly street driven. I'm still in the planning stage right now, what do most people put down with an engine this size supercharged? Will a p1sc or p1x be enough for my needs? The reason I'm deciding to go supercharged is that I can build a more tamed engine with more power. Is it woth it to use the ls7 top end over the ls3 top end?
Old Feb 21, 2019 | 08:36 AM
JoeNova's Avatar
Restricted User
A stock 4.8 with a D1x would make more than 600whp.
If you're going boost, you can literally use any head/intake combo you want, even factory stuff, and 600whp will be done by accident.
I would probably go the cheap route and toss on stock LS3 heads/intake for now. You'll make 800whp with a D1x and stock LS3 top end on pump gas by accident.
Old Feb 21, 2019 | 12:20 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
A agree. A D-1SC with 8 psi with the LS3 heads and intake can make 700 rwhp with a good cam on that combo. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Feb 21, 2019 | 11:33 PM
Detoxx03's Avatar
It’s a great blower and can easily meet and surpass your goals.
Old Feb 22, 2019 | 07:39 AM
qweedqwag's Avatar
Bob is there a direct bolt on kit for an LS1 like this http://rmcrperformance.com/rmcr-low-mount-manual.pdf
Old Feb 22, 2019 | 07:55 AM
LS1Tech Sponsor
https://shop.brutespeed.com/98-02-F-...stems_c536.htm
Take a look at the above link. ProCharger has had their kits in this location for the 98-02 F Body since the early 2000's. Thanks. Bob
__________________
Old Feb 22, 2019 | 10:52 AM
qweedqwag's Avatar
Not a fan of the intercooler location. Looking for a front mount intercooler.
