LY6 + 243s + Turbo?
Old Feb 26, 2019 | 03:58 PM
dewchugr's Avatar
Default LY6 + 243s + Turbo?
I had an aluminum 5.3, already got the 243 heads redone, already have a GT45 turbo, already have the TBSS intake, "SS2" cam and fbody pan and a 4L80.
Found out the 5.3 isn't going to work without some machine work and that's not in my budget.
Picked up an 09 LY6 short block that I want to use. Is the compression using 243 heads OK with a turbo or to high? Strictly street car, more interested in reliability than maximum power. I think everything I bought will port over to the 6.0 except the head gaskets. Prefer to run 93.
Old Feb 26, 2019 | 05:51 PM
2kgtp's Avatar
As long as it has a good tune and you aren’t crazy with the boost i dont see a problem with that combo. I ran my 10:1 compression ls1 on 16* and 9#’s with no issues
Old Feb 28, 2019 | 01:05 PM
408GT's Avatar
I ran 18#'s on an L92 (10:7:1) for awhile w/o any issue. Use good fuel and be conservative w/ the timing.
Old Mar 1, 2019 | 09:21 PM
kunta0908's Avatar
Dyno'd 851hp on my LY6 w/243's... that was at 13lbs of boost from an old cast On3 88mm w/e85.
Have ran it up to 18lbs on the street without issue.
