iat sensor before or after throttle body?
Old Feb 28, 2019 | 03:51 PM
jeffs55chevy's Avatar
Default iat sensor before or after throttle body?
on a turbo application less than 15 psi, is it better to have the iat in the truck intake manifold( where the evap purge solenoid would be) behind the throttle body, or in the aluminum pipe between the intercooler and the throttle body? ive seen it done both ways many times with push in and thread in iat's. any real benefit either way? thanks.
Old Mar 1, 2019 | 04:50 AM
brandon6.0's Avatar
Either way works. Less heat soak with it in the plastic manifold.
Old Mar 1, 2019 | 05:43 AM
freeky's Avatar
if you spray meth where doo you want the senser ? after im guessing
Old Mar 1, 2019 | 09:19 AM
thats what i was leaning towards because of heat soak. thank you.
