Ring gaps..??
Old Mar 2, 2019 | 12:22 AM
chinaoreo's Avatar
Default Ring gaps..??
So this is not an ls motor but I thought it was a good place to post my question..any info would be appreciated. Ok so I just put together my bottom end on a 6 cyl twin turbo car.. the bore ie 3.445.. my top ring gap was 22 so I left it alone.. but I got a lil wild with the file and gapped the bottom ring to 28-30.. did i go too far..!? Will it be fine or should I order another set of rings and redo the 2nd ring to closer to 24-25..? Does 5 thousands make that much difference in compression.. ? I run 15 lbs of boost..
Old Mar 2, 2019 | 12:33 PM
3 window's Avatar
Run it
Old Mar 2, 2019 | 06:54 PM
jester1's Avatar
That's what I'm at on a 5.3. In fact this engine has about a little over 100k km and the stock gap was 16-17 top and 25-30 on the bottom.
Old Mar 3, 2019 | 12:17 AM
chinaoreo's Avatar
Ok thanks a mill guys..
