Would a leaking wastegate affect AFR at idle?
I recently found that my wastegate dump tube has a good amount of exhaust coming out of it, you can feel it and hear it.
Could this affect the AFR at idle? My dump tube is about 3 feet long, so it's not like air can easily enter the main exhaust hot pipes leading to the wideband (or maybe it could?)
I also plugged up the wastegate dump tube, completely eliminating the leak - but the AFR stayed the same as well.
My issue is, as the car sits idling, it goes leaner and leaner (very slowly). At this point, I'm starting to think it is a fueling issue, or maybe an exhaust leak from a hot pipe v-band that leaks more and more as the car gets hotter under the hood
To the OP, what does you IAT sensor do while this is going on? Are you running OLSD? A lot of guys have an issue with the IAT heat soaking and the computer makes it run leaner.
also make sure you have enough vent on the tank. I went through 3 or 4 fuel pumps before I figured out I needed more vent. Lol I'm stupid sometimes.
