ZL1 cooler pump wiring
Old Mar 27, 2019 | 09:13 PM
dcs13's Avatar
Default ZL1 cooler pump wiring
The stock ZL1 cooler pump has a 3 wire hook up. Changing the pump to a 2 wire Meziere pump.(cleaner install, more flow, An fittings). Obviously theres a ground and a power. Is the 3rd wire on the stock pump a low amp reference or what is its function ? thanks in advance.
