Turbo build
Old May 10, 2019 | 05:32 AM
rkreigh's Avatar
Default Turbo build
I have a tired LS6 in a z06 with TTix twin turbo
Like to get some advice from the turbo guys
I have a 4.8 iron block with stock std crank, gen4 rods, and wiseco forged pistons
wanted to see if I can reuse my AFR 225 heads, and possibly a BTR stg II turbo can
car is an automatic equipped 4l65e with 3 disk precision conv and the TTiX with the smaller 58/62 t3/t4 hybrid ball bearing turbos
I'm thinking of upgrading to the larger .84 AR exh on the turbine, and I have champion 3" down pipes
here are my questions. will the stock crank and gen 4 rods with wiseco 9.5 -1 pistons live a 900 or so engine HP
I'm targeting around 800 at the tire which is the limit of my current trans
I'm running 127 FIC injectors and coverting over to flex fuel e85
thanks for any advice!!!
