View Poll Results: Plugs for 800 rwhp ProCharger
NGK BR7EF / 3346 - Heat 7, Resistor, Tapered, V-groove
6
60.00%
NGK BR7EFS / 1094 - Heat 7, Resistor, Tapered
1
10.00%
NGK R5671A-7 / 4091 - Heat 7, Non-Resistor, Gasket, V-groove
1
10.00%
NGK B8EFS / 1049 - Heat 8, Non-Resistor, Tapered
0
0%
NGK R5671A-8 / 4554 - Heat 8, Non-Resistor, Gasket, V-groove
2
20.00%
Voters: 10. You may not vote on this poll
Help me pick my next set of plugs
Old May 26, 2019 | 02:02 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Why are tapered or gasket choices? That depends entirely on the hole in your head. Also, those old "rule of thumb" heat range ideas are fairly outdated. As you noted, you would quickly be using an entirely unreasonable heat range with modest horsepower gains.
Old May 29, 2019 | 03:08 PM
white01ss's Avatar
Pick another few and you could run a different plug in every hole.
Interesting idea!
Old May 29, 2019 | 04:14 PM
white01ss's Avatar
From what I read if your head supports tapered plugs then it will most likely work with gasket plugs. But if the head has a flat mating surface then tapered plugs won't work. My TFS 220 as cast heads have stock LS1/LS2 style tapered holes so either style should work.
That's why I started this thread. I know there's a bunch of folks out there that been there done that. I just need them to tell me what they done.
Old May 29, 2019 | 04:17 PM
white01ss's Avatar
I made 1075 wheel on some 7's
Impressive! Seems like a very versatile plug. I'm swaying back to the 7's.
Old May 30, 2019 | 11:51 AM
tblentrprz's Avatar
what do the plugs look like? how many threads are showing heat?
^^^^ this?
More than 1 thread, go 1 colder.
Old Jun 8, 2019 | 11:30 AM
white01ss's Avatar
Two year old BR7EF plugs are out. They are pretty sooty but at least the gaps look good. Car had been idling very rich up until lately when I finally got around to getting the MPW of the 96 lb'ers in check.
Old Jun 8, 2019 | 01:34 PM
NicD's Avatar
7 Second Club
If you can run a gasket seat plug with your heads by all means do so. I like the NGK R5671A-8 for your power level assuming your tune up is clean it won't cause any problems. Really though the plug will tell the tale after making a pull on fresh plugs but if you aren't fouling out 8s then that would be my starting point on that combo.
