New P.B. and a couple of wheelies
Old Jun 21, 2019 | 07:48 AM
408GT's Avatar
Originally Posted by ls3fox
It’s on pump e85 that’s usually about 78% and i think the cr is around 10.6-1
Sounds like I need to pin the gate shut on mine. I did an SME rod/piston in my L92 in the LTD, and dropped the c/r to a little over 9:2:1. It went 118 on 18 psi avg @ 3600 lbs w/ an 80e. I haven't had a chance to get it out this year. Your combo gives me hope lol.
Old Jun 21, 2019 | 05:10 PM
ls3fox's Avatar
7 Second Club
118@3600lbs is moving but I like this pin the gate shut talk lol
at 18 psi I’m sure there’s plenty left in it and with rods and pistons I wouldn’t be worried about getting it in early either
good luck with it
Old Jun 21, 2019 | 07:31 PM
H.P.Ranch1's Avatar
LS3fox care to share what percentage antisquat you ended up with running radials? I have mine set at 175% have not tried it yet 6.0 160's 275 pro's, notch, same turbo, glide 1.76, 3.89 9", 1/8 mile, thanks for the info.
Old Jun 21, 2019 | 08:12 PM
ls3fox's Avatar
7 Second Club
It’s set at 160% right now, seems like we have almost the same setup curious how yours will 60’ with the 3.89 gears maybe you can post how you make out with it
Old Jun 21, 2019 | 08:29 PM
H.P.Ranch1's Avatar
It will be a while before i get to try it still doing some wiring and tuning. My next hole up is 3/4" up and my anti drops to 143% no wheelies wanted. What percent were you at when you had the wheelie problem? Strange single adjust 125lb. coilovers. Keep us posted on your outings fun to watch and makes me want to work on mine.
Old Jun 22, 2019 | 08:09 AM
ls3fox's Avatar
7 Second Club
It was the same antisquat as when I did the wheelies, I didn’t have the front end tied down far enough once I limited the front end travel it made the 8.01 pass
Old Jun 24, 2019 | 09:35 AM
408GT's Avatar
good luck with it
I went out Friday night and tried to get some passes in for the year, but the converter didn't like it. I left on about 11psi w/ a straight ramp to 25psi, and it only went a 6.00 @ 115 and 9.4 @ 146, w/ maybe 100 rpm drop on the shift lol. Time to put in my new PTC I guess.
Old Jun 24, 2019 | 11:27 AM
ls3fox's Avatar
7 Second Club
Whoo that’s the tune up, now you just need the converter to hold that power, out of curiosity what did you shift at?
Old Jun 24, 2019 | 12:52 PM
408GT's Avatar
I think I have it set to 6200 and 6500. I have a D3 brake and a 10" PTC lu converter in it now (Cadillac core). I have a 9.5" non lu I'm about to put in. I went 120 in the 1/8 before on about 20psi.
Old Jun 24, 2019 | 02:54 PM
ls3fox's Avatar
7 Second Club
Yea either you have to shift it higher so it can couple harder or it’s time to change the converter. I love the car thow so low with the big wheels looks great 👍🏻
Old Jun 24, 2019 | 03:45 PM
408GT's Avatar
Thanks! I'll keep you posted on how it does w/ the new converter. Good luck w/ getting yours into the 7's!
Old Jun 24, 2019 | 04:58 PM
  #32
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
8.01 sweet!
Old Jun 24, 2019 | 05:14 PM
  #33
47ford's Avatar
I was pumped to get in the 9s with a 6.0 and an s480 then I got to read this stuff! LOL Congrats man that thing moves out!
Old Jun 24, 2019 | 06:25 PM
  #34
ls3fox's Avatar
7 Second Club
yes keep me updated would love to see what it can do when you get it sorted out and thanks
8.01 sweet!
thanks man
Lmao thanks man
