Methanol injection
Old Sep 12, 2019 | 10:45 AM
Chad powell's Avatar
Default Methanol injection
I'm new to this site needing some help with methanol injection I used to run e85 what is no longer available near where I live wondering timing and boost levels on e85 can I still run the same 100% meth injection I have a 5.3 that was bored to 5.7 I have a s475 non intercooled running a truck intake and using megasquirt ms3 71 Camaro 400 turbo 9in rear end e85 I run 18 lb of boost 16 degrees of timing just wondering would meth and 93 and can I do it with a single nozzle or do I need dual nozzle to get me that closeI will I need to back off the boost and timing thanks for any help
Old Sep 12, 2019 | 10:59 AM
JoeNova's Avatar
Restricted User
Non intercooled?
No. You'll need about 6 degrees less timing to start and then creep back up on it.
Old Sep 18, 2019 | 05:45 PM
customblackbird's Avatar
Agreed, less timing and you gotta be careful with 100% meth as it has a super low flash point. At 15psi I'm at about 14-15* on 93 pump with wiper fluid, on a mostly stock 5.3 (ported heads and a cam) but I also run a FMIC so my IATs are around 100-120*F on a 90*F day in boost closer to 90-100*F with the meth on. I usually see a 10*F drop in temps during a 3-5s pull some of the temp drop is still going down coming out of the pull.
Old Sep 18, 2019 | 06:27 PM
imma_stocker's Avatar
Keep in mind you won't have the benefits of alcohol until the methanol starts spraying so you don't get as much low-end benefit.
Watch those temps, EGT, and AFR like a hawk.
