Drive belt damage
Old Oct 21, 2019 | 01:52 PM
Jtuck3967's Avatar
Default Drive belt damage
I have a 99 Trans Am recently installed a ProCharger it throw the drive belt and a/c belt when i finally found a place to stop oil was dripping from the timing cover seal. Has anyone else had this issue. If so was it just the seal or cover leaking.
Old Oct 21, 2019 | 07:35 PM
00pooterSS's Avatar
Sounds like the balancer may have come loose.
If you didn't pin the crank for the procharger that will happen even if you get the bolt tight enough. If it is pinned and came loose then the bolt most likely wasn't tight enough.
